    May 2002
    Ontario Canada
    I have an AVI file that is encoded with XVid. I want to burn this file to cd using TMPGenc but am having troubles. Shouls i be using another program or do I need a special codec for this?
    As usual, thanks in advance
    Apr 2002
    The State of Frustration
    Do you have the Nimo Codec Pack installed?
    Hello.
    May 2002
    Ontario Canada
    Yes I have the Nimo Codec installed
    Apr 2002
    What kind of problems are you having?
    Hello.
  5. Use expand to expand the audio into pcm format in the avi. Then encode with TMPMeg putting the avi with expanded audio as the audio source.
