Hi guys I want to know whats the best tv out that I could use with my big screen tv..??? I would like to put a 80gb hardrive on a dual celeron 500 that I'm not using and use this machine as a backup of all my tv shows and specialy my vcr tapes so!!! I need a good capture card that has a good out for my tv.. has anyone done this??? is it worth it???
thx in advance
OH can I play my divx movies on the tv out to my big screen tv and they would look the same??? or tv out lacks of quality (good q or bad q)??
Hi,
The quality of a DivX movie on a TV is (In my oppinion) better that on a monitor. This is caused by the fact that a TV has a (slighty) lower resolution for displaying screens than a monitor. Also a TV gives a more natural look.
If you really wanna go for good quality display (In both TV and PC mode) get your self a Matrox Millenium G4xx. They are relitivly cheap and the TV-out is THE best you can get for that price-range. You won't be able to do really heavy 3-D games, but the screen quality is really great. (Most games will run just fine though, just not at full speed/quality)
Greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success ! -
hey thx remember that I won't use this pc for nothing other than capturing video from my vhs and playing video through my tv out
I have 9 computers at home:
3 game/workstation pcs
1 linux/webserver/file server/cold fusion server
1 linux router
2 future linux cluster pcs
2 I don't know what to do pcs; one of them the dedicated tv/out capture server and the other one maybe a linux answering machine where I can listen to my messages online and I can put a password on the phone so that telemarkers can't get through
That being said what do you think would be a good capture card and just for tv out and vhs captureno playing games (dual 500 celeron with tnt2 or single 700athlon mhz with 3dfx; either one) dedicated tv out and vhs capture pc with internettt to download the movies and then play them
I agree with Psycho_Dad_Rules, Matrox DualHead/TV gives the best quality you will EVER find in any other competing product, as it's designed specificly for that objective, it's 3D isn't exactly the best, but when it comes to what it says it will do, it will do it better then any other card.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
yes I have to agree the card looks very good.. I've been looking at the Matrox Marvel G450 eTV it say its at $250 but I saw it at 90 in pricewatch????? Are they not the same card?? oh one more thing can I use virtual dub with this card to capture in divx???
thx in adavance -
There are many variations of the card, one would be the regular DualHead which you can connect two PC Monitors or a PC and a TV, and the other would be the card with the Capture ability which is the more expensive one, basicly one is named Millenium and the other Marvel.
the one with the capture (Marvel) is more expensive, and it can use any capture program in the market.
Best Regards,
Sefy Levy,
