How do I install CDRAO or whatever? I'm using Windows XP Pro and the installer I think is for MS-DOS, help please!![]()
I've never actually seen an installer for cdrdao, I've only seen it bundled with other programs (like VCDEasy) or in a zip file. cdrdao is a command-line utility, ported to Windows from UNIX using the Cygnus cygwin32 toolkit. If you have cdrdao.exe in a folder just open a command prompt to that folder and try "cdrdao -h" to get a usage message.
You could of course just download the Win32 build from slashdot but, it is easier to use it with a GUI.
You could use VCDEasy (which is also a GUI for VCDImager) or XDuplicator which is a freeware Win32 GUI specifically for CDRDAO.
Regards.Michael Tam
w: Morsels of Evidence
Cannot Install ffmpegX
By FunkyBeccaBecca in forum ffmpegX general discussionReplies: 1Last Post: 14th Oct 2011, 12:26 -
will not install
By ka3wjz in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 30th Jun 2009, 22:07 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 14:43 -
Use without an install
By raschko in forum Newbie / General discussionsReplies: 0Last Post: 9th Aug 2007, 17:37 -
install
By Brasilman in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 29th May 2007, 10:17
