Just got the DAV-C770 this week and almost completely satisfied with it. Except two things...
1) just like the DAV-S300, there is a momentary pause in the middle of the disc. My friend says it might be changing layers or something. But it always happens around chapter 14-17... depending on the disc.
2a) This is my biggest annoyance. I think the way the DVD player's software is programmed, it puts on english subtitles as default. When I try to eliminate this, as in set it to "off", there is no such option. This is somewhat tolerable,
2b) except that's not the end of it. When the disc pauses as described in complaint #1, it turns the subtitles back on! Which means I have to go find the remote on to turn it off. This happens on almost all dvds.
Does anyone know how to fix this, does anyone wlse who owns this system see this happening? Not happening?
Thanks in advance.
Note: I was also a little disatisfied with the sub. It is designed with unnecessary panels for aesthetic purposes. These panels vibrate horendously, and create a buzzing sound. I had to weight it down with a few reams of paper to dampen the vibrations.
Results 1 to 1 of 1
Sony dav-s400
By jdaml in forum Newbie / General discussionsReplies: 0Last Post: 24th Aug 2010, 12:56 -
Sony DAV-DZ360WA
By pablogarciavera in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Dec 2009, 17:15 -
Sony dav-fr1
By Gerard Russell in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2008, 16:42 -
Sony DAV-DZ20
By Bena in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2008, 13:23 -
Sony DAV FX100W
By alexu in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Jan 2008, 10:26
