I can't quite seem to figure out how to convert an AVI file to an MPEG file with Virtual Dub. I followed the guide. But then how do I save it as an mpeg? I tried saving it and just typed in a .mpeg tag. But when it was dubbing, it was saying finished file size 300 mb's, and the AVI size is only 4mb. Can i get some help here? Thanks
i think you better do ALOT more reading! virtual dub does not make mpeg's.
[/b]
arg... then what can i use to convert it? or is there a program that allows you to burn SVCD's with avi files?
One of the popular ones is TMPGEnc. But you are going to have to do some reading, you know.
Hello.
MPEG-2 VOBs trouble in VirtualDub
By shmizan in forum Video ConversionReplies: 4Last Post: 16th Apr 2010, 09:35 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Virtualdub codec MPEG-2 / MPEG-1
By Astrogirl in forum Video ConversionReplies: 19Last Post: 10th Dec 2008, 11:38 -
using virtualdub mpeg-2 for cropping and need advice
By mrgain in forum EditingReplies: 2Last Post: 10th Jun 2007, 10:59
