HOw is the best way to make a multi-episode TV-DVD.
It has like 6 or 8 episodes.
Should I put it all in VTS_1 folder and make each episode a chapter?
Should i combine it all into a big MPEG and make chapters.
Should I create VTS_2, VTS_3, etc
I WANT THE EASIEST WAY. Im using Sonic Scenarist, but could use DVDit.
I wanna use Scenarist though.
I"ll need to move the final product, the DVD image, to anouther computer via CD-R
If you have each episode by itelf, it is surely the easiest to just add each file and it will become a chapter when you play the DVD. It will save you a lot of work from making one huge mpeg file and set chapter points.
I like Ulead DVD Moviefactory because I don't want a menu, I simply want the DVD to start playing when I put it in the DVD player. This can be done very easilly unchecking the menu button in Ulead. Adding each mpeg file will automatically add it as a chapter, and I can use the skip button to move forward and backward between the files when playing the DVD. The DVD works just like a VCD without any menus.
Convert Multi-episode DVD to 1 avi file
By cfs6254 in forum Video ConversionReplies: 2Last Post: 16th Jan 2011, 02:26 -
Ripping a multi-episode DVD
By scoopyx in forum Newbie / General discussionsReplies: 5Last Post: 21st Dec 2009, 22:55 -
I have a problem with ripping multi-episode DVD
By jemping in forum DVD RippingReplies: 7Last Post: 27th Oct 2009, 11:42 -
have a problem making multi-episode dvds??
By roboroach in forum SubtitleReplies: 0Last Post: 18th Dec 2008, 16:39 -
Multi Episode dvd's with single title, Ripping troubles
By Malicious in forum DVD RippingReplies: 11Last Post: 5th Aug 2008, 09:32
