I've been pretty good at making VCD's with chapters using the Sefty's Guide. Last night, I wanted to make a SVCD of Lord of the Rings on 3 CD's. I'm uising TMPGEnc and encoded the movie in 3 parts, 750mb each, using CQ of 80, with the high bit rate of 2400 and a min of 900.
I used Chapter X Tractor to read the IFO and pasted the info into VCDEasy, but VCDEasy said "number of possible chapter entry points:1".
Is it because I made a non-standard SVCD?
Well, after several trials to determine the problem, I finally discovered why. It was the bitrate. Once I changed the max bitrate to 2520, VCDEasy was able to import the chapters using Chapter X Tractor. If I deviate from 2520, no chapter points can be entered. I haven't tried this with a VCD by altering the bitrate, but my guess would be the same result: no chapter points.
when you encode with TMPGEnc you must in the GOP tab the Output bitstream for edit = ON. and Output Interval For Sequense Header must be 1 GOP's
(sorry for my bad English)
How do I get chapters and searching to work in a .TS stream
By jack616 in forum Video ConversionReplies: 10Last Post: 22nd Apr 2014, 08:57 -
Chapters no longer work after adding audio to DVD.
By Nagashi in forum DVD RippingReplies: 4Last Post: 25th Jul 2010, 18:27 -
TmgEnc DVD Author Menu Problem
By powerkoala in forum Video ConversionReplies: 9Last Post: 25th Sep 2007, 14:19 -
Tmgenc DVD Author
By powerkoala in forum Video ConversionReplies: 10Last Post: 19th Sep 2007, 07:02 -
Tmgenc problem after going "fullscreen to wide"
By spiritgumm in forum Video ConversionReplies: 0Last Post: 21st May 2007, 10:26
