Big problem!!!!!!!!!!
I downloaded a nice AVI-film, good quality, good audio.
Problem: When I want to convert to MPEG with TMPGEnc, there is no sound anymore.
I hope anyone can help me out with this problem.
Thanks anyway![/b]
Results 1 to 15 of 15
I'm a newbie myself but I had this probelm with a Divx that did the same. Installed Nimo Codec pack and this sorted it out fine! Hope this helps!
You also might need to use VIrtualdub to extract the audio as a WAV then use WAV as audio source in TMPGE
"Today is only yesterdays tomorrow" -
I have the exact problem, so I dwonloaded the Nimo Codec Pack, and the I tried to re-encode my video with TMPGEnc, and the same thing happened. There is still no audio. I tried extracting the wav from VirtualDub but thats not working either. Is there something else I have to do?
Do you mean that you can't open file in Virtualdub ?Originally Posted by Mike2K17x
or
You did extract and save the WAV ,but it does'nt encode with TMPGE?"Today is only yesterdays tomorrow" -
What I mean is: I can open the file in virtualdub and I did extract the wav, but even when I use that wav file as the audio when I encode it in TMPGEnc, I still don't get any audio in the resulting mpg file. Everyone says to download the nimo codec pack, and it will work, but it still isn't working. What should I do?
Yeah, but the wav is supposed to be 21 minutes long, and the wav is only 8 minutes long. But still, when I try to encode the video file with its own audio it still doesnt work.
I.m a bit confused....Originally Posted by Mike2K17x
the video/audio is supposed to be 21 min long....
but the extracted WAV comes out as 8 min??
so--...when you listen to this 8 min clip ,does it sound like chipmunks or is it chopped?"Today is only yesterdays tomorrow" -
No, It all sounds normal, but then the wav just cuts off at 8 minutes. The actual audio sounds fine when I play the avi, but when I encode it using the actual audio, it doesnt come out.
ok....how a bout getting :
DivFix or Virtualdub (video freeze version from )........
http://www.digital-digest.com/dvd/downloads/virtualdub.html
scroll down to mp3-freeze version.
scan for bad frames and extract."Today is only yesterdays tomorrow" -
Ok that version didn't save a wav file at all nothing happened. Is there any way to avoid using a wav file and just use the original audio?
Virtualdub > File > Open >(movie title) > Audio > full Processing Mode > Audio > Compression > no compression(pcm) > Audio Conversion > 44100 (if VCD) > File > Save as WAV.
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
Vob2mpg audio missing
By LSBREWER in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 14th May 2011, 09:24 -
Audio Source Missing from VirtualDub
By Flynn in forum Capturing and VCRReplies: 3Last Post: 5th Jun 2010, 05:58 -
PIP Missing audio
By john920 in forum Blu-ray RippingReplies: 0Last Post: 22nd Jan 2010, 22:02 -
Partially missing audio
By DEMNz in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2007, 18:15
