when i download a divx from the web and take the audio out with virtual dub and the convert it with tmpegenc, sometimes the video doesnt match up with the audio during some points in the movie. (ex. when i ripped colateral damage, the whole thing was messed up, and when i ripped office space it didnt start til the second disc.) any idea why this is happening? And what i can do to fix it? Any suggestions would be appreciated.
thanks.
you are saving the WAV file as uncompressed?..yes?
"Today is only yesterdays tomorrow" -
wheel i had the same problem, I am guessing it has something to do with the collateral damage divx, b/c it usually works fine. But I figured out why it did it. The audio file needs 7 seconds of no play in the begging to be synced with the video and for some reason virtual dub only takes 1 second of it..
found out how to fix it, in tmpgenc, you use the "audio gap correct" feature in the source range window.
How to sync subtitiles to match Video/Audio
By VidHunter in forum MacReplies: 3Last Post: 17th Nov 2010, 15:55 -
Audio does not match with the video
By c018279 in forum Blu-ray RippingReplies: 1Last Post: 31st Mar 2009, 04:10 -
Video and Audio does not match
By hzgg2 in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 19:50 -
cant get audio to match video
By loa909 in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 06:35 -
Conversion of audio to match video
By deltaromeo in forum AudioReplies: 11Last Post: 29th Jan 2008, 12:01
