i have been trying to make a good quality VCD for more than a month now.. but always end up with videos that are problematic which include BLOCKS all over..
can anyone enlighten me as to what VCD settings i should tweak, consider to produce good quality VCD .. good quality, meaning getting rid of the BLOCKS...
i capture my video using a firewire card from my SONY DCRPC110.. do some editing with VEGAS VIDEO and render it using VV3's default template (or should i render my video using the highest template settings?) and encode my video using TMPGENC where i think the key to my problem lies....
thank you very much for all of your future help
Use the templates under the Load option in TMPGEnc. If they give you inferior results, try Kwag's templates www.kwag.net
Hello. -
You cannot get rid of all the blocks in a VCD. The bit rate is to low for that. You will always have to live with some blockiness in a VCD.
To get block-free video, you need to increase the bit rate to 2.5Mb/sec or so, over twice the bit rate of VCD.
To minimize the blockiness, make sure the video source is noise free, and use a noise reduction filter to reduce noise. Tmpenc has a good noise reduction filter. Set it at 100% for VHS video tape. -
tried kwags templates to no avail.. cant say my source video is inferior either.. i use a SONY DCRPC110 and a firewire card to capture from it...
tried making SVCD too, but the blocks are still present.. is there anyway i can rid of the blocks in SVCD if not in VCD?
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
Mpeg4 Settings for TMPGenc give poor quality for motion.. see pic's
By drewzor in forum Video ConversionReplies: 14Last Post: 13th May 2009, 08:37 -
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 00:21 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18 -
TMPGEnc advanced settings for best quality results
By tdavid232 in forum Video ConversionReplies: 1Last Post: 15th May 2008, 18:02
