  1. How can I fix the lag in the sound of the AVI file after I convert from MPEG2?
    Its annoying as H***
  2. Use TMPGEnc 2.53 and then go to
    File; Mpeg Tools
    Click the "Simple De-Multiplex" tab and then click browse for source and select the file your having issues with and then click browse in video output and the audio output fields and make names for files and the click "Run"
    After that go to the "Simple Multiplex" tab
    Click the drop down in "Type" and select Super VideoCD
    Then select the two files u extracted and an output file name and that should resync your sound to your video...
