  1. Hi
    I'm using (or trying to use!) VCDEasy (v1.1.1) to build a VCD, I've coverted my AVI file to MPEG-1 which become with a size of about 1Gb, when I tryed to duild the VCD, I alwais get then same Error Mensage ->
    "image too big (468908 sectors > 449850 sectors)"
    More - the file is OK, it runs well in the media player...
    can somebody help me? tx in advance!
  2. Banned
    Jun 2001
    UK
    Now tell me this... How much room is there on your blank disks in Mb ? 700Mb ?
    So I guess a 1Gb file wont fit on a 700Mb disk, that’s roughly 300Mb too much don’t you think ?
    Here's a good Idea, why not split the 1Gb into 2 X 500Mb mpeg's then use 2 disks
    TMPGEnc > Mpeg tools > Merge&Cut
