I have an avi file and when I try to convert it with TMPEGnc into VCDPAL I have no audio.
the avifile's audio is MPEG Layer-3, 159kbit/s, 48.000Hz, Stereo. Now I noticed that on TMPEGnc it is MPEG Layer2, 224 kbit/sec, 44.100Hz,
Is there a Template for TMPEGnc to use that MPEG Layer3?
Or is there another software to get audio.
I hope someone can help me
Porthos13
If you cannot get the audio, changes are you have a missing audio codec, install the Nimo codec pack. Use a PAL VCD template and TMPGEnc will convert 48Khz to 44.1Khz it will also convert AC3, but if you get any problems you make need to save out the audio in Vdub first.Originally Posted by Porthos13
Also check this;
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
