I have download a lot of audio book file in mp3
what is the best way to burn them without any click and jumps.
I used nero and burned them at 2 x , but when I played it on my DVD player it jumped and made loud crash noises.
help.
there are som 20 files to a book and I can get 3 books to a disc.
I do not use folders just place the files in a row.
the dvd player is xms 750
i have the same player. clicks and jumps are usually caused in the ripping, not the burning due to no jitter correction and small buffers.
with the loud noise that comes from some mp3's, it is sometimes because the file is vbr or corrupted somehow. a corrupted mp3 usually will play ok in winamp or such - but when burned to cd wont work in a stand alone player. if you make an audio cd from mp3's nero scans the files looking for errors and should pick up the bad files. if i come accross a corrupt file or a vbr file i convert them to wavs using winamp.
hope this helps.
oO ELVIS Oo -
thanks nero does not pick up any errors ,
once the disc is burnt it plays great on the computer cd but not in the msx dvd player .
thats the whole idear .i want to use the audo books when i am away in my mobile home.
is there any burning tips that would held.
the sound is like when one burns a vcd movie badly and it breaks up in the sound. hope that helps -
My only suggestion would be to try and re-encode the files with a tool called RazorLame. You can find it at: http://www.dors.de/razorlame/index.php
With this you can convert them back out to wave or just re-encode them directly. Also it's free! -
thanks . gee i am so new to this what does encoding do to the file
and will it still stay in mp3 format.
next what program can i use to cut the first 2 seconds off the files , some are quite long -
... you could also use electonic cosmo's mpeg suite to convert. that is what i use it is really simple too.
to trim your files there is a program out there i think is called mp3trim or something similar. it is a small download available from download.com
oO ELVIS Oo
question on speakers with MP3 playing capabilities
By ktnwin in forum Portable VideoReplies: 3Last Post: 10th May 2013, 22:16 -
question. FAAC or MP3 lame for videos
By llmercll in forum Video ConversionReplies: 4Last Post: 1st Feb 2009, 22:05 -
question about how to extract mp3 audio from DVD
By jimdagys in forum AudioReplies: 5Last Post: 17th Apr 2008, 10:19 -
MP3 Player question
By Franza in forum Off topicReplies: 3Last Post: 15th Nov 2007, 17:47 -
mp3 conversion question
By tecstar in forum AudioReplies: 7Last Post: 10th Jun 2007, 21:19
