My FujiFilm's don't work, it says NO DISK.
I think I am doing the burning right.(NERO) select VCD move the movies over and burn with no errors coming up.
Results 1 to 10 of 10
Does your DVD player play "CDR" VCD ?
Maxell discs are fine, but if you DVD player does not play cdr, then you have no chance
Are you making the mpeg 1's in TMPGEnc, and loading a PAL/NTSC template -
GuestI use Fuji's in my Apex 1100w. On my second attempt at making a VCDOriginally Posted by ViperVisor
I loaded it up and got the "No Disc"message. I ejected the disk, turned
it just a little with my finger and loaded it up again. This time it worked.
Why, I do not know. Maybe something about where it starts to look for data? -
GuestI know I know. I have done this before with music CD's. I do not rememberOriginally Posted by KingJohn
where I heard of doing this but it worked.
I just tried my 2nd VCD again today and I had to eject it/insert it
to get it to load properly. My first VCD works great! I don't know why
my 2nd one doesn't work as well. Everything was done "By the book"
to make it.
If you have trouble in the future just try it. It works for me most of the time. -
in my experience, if the set top will play cd-r, it will play ANY cd-r. this is obviously not true with dvd-r media, but I always buy the 30 cent cd-r and they work great in both my players.
Andy
Ejecting the disk and putting it back in, may fix a bad read error, but moving it wont have any effect at allOriginally Posted by Megadeus324
Ok, so you made a mpeg 1 with TMPGEnc and loaded a VCD template. Then you dropped it into Nero !, Nero should not be used for any conversion, always use TMPGEnc to make the mpegs.
Only thing left is the quality of the disks, you need to try a higher quality one -
TDK,Kodak or Memorex will be best.If CD-R wouldn't play CD-RW might.I had experience of this
Is it possible to do multisession VCD burning with Nero V5.572?What do track at once and disk at once mean?
New guy saying hi
By Hanssen069 in forum Off topicReplies: 13Last Post: 8th Jul 2011, 18:20 -
never mess with an old guy on the bus
By deadrats in forum Off topicReplies: 4Last Post: 5th Mar 2010, 23:54 -
new guy
By harrisonhouse in forum Newbie / General discussionsReplies: 0Last Post: 26th Mar 2008, 08:03 -
How did this guy get on tv?
By redstripes in forum Off topicReplies: 2Last Post: 25th Jan 2008, 17:31 -
Who is this guy that is trying so hard???
By fLYtRap in forum ComputerReplies: 12Last Post: 1st Jul 2007, 18:06
