  1. I downloaded a mpeg from the net.
    tried to play on Media Player but I get the message:
    This format is not supported
    but when I run it on QuickTime It works fine (As a mpg not as MOV)
    I tried to encode with TMpgenc but I get the same message
    What can I do to fix the problem?
    Apr 2002
    The State of Frustration
    Some common TMPGEnc problems:
    If you get an error message when opening the video or audio like file unsupported
    or you get an empty(black) video preview window
    or the video look wierd in the video preview window like green or purple or pink
    Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
    -- http://www.vcdhelp.com/tmpgenc.htm#problems
    Hello.
  3. It worked on one MPEG but the others still does not work.
    It works fine on QuickTime and it's not working on MediaPlayer
    HELP ME PLEASE
  4. Maybe they are mov files and not mpg files?
    Panasonic DMR-ES45VS, keep those discs a burnin'
  5. Sorry
    I tried changing it to MOV and its not working
    it works only as an MPG on QuickTime (and on the file info- on quicktime player- it shows that it is a mpeg) I installed NIMO Codecs.
    is there another Encoding software other then TMPGEnc but as good?
