I'm trying to create an SVCD with dual language and selectable subtitles (anime).
I'm stuck trying to multiplex the MPEG2 file, audio and subtitle wise.
Perhaps the problem lies with the encoding of the video stream.
It began as frameserved AVI from VirtualDub. It was processed through TMPEnc as MPEG-2 Video, 480 x 480, 4:3 aspect, 29.97 fps, 2-pass VBR, NTSC video.
In the TMPEnc settings menu, under the video tab, Encode mode: Inverse 3:2 pulldown is selected (it is suggested by TMPEnc for anime). Under the Advanced tab, 3:2 is again selected. Might the two be cancelling each other out?
Each audio stream is 192kbps/44Hz. When I multiplex them together, I cannot watch more than the first few seconds before any viewer hangs.
Also, I cannot get subtitles to mux into either the video-only stream or the post multiplex MPEG. I have tried several formats of subtitles in SubRip. submux and winsubmux refuse to accept any format of subtitle.
Any thoughts?
Results 1 to 1 of 1
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 16:24 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
I am stuck with closed captioning/subtitles?
By Rjupiter in forum DVD RippingReplies: 7Last Post: 3rd Aug 2008, 16:21 -
How to burn a mkv file to dvd with dual audio and subtitles with nero.
By drkcloud in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2008, 04:48 -
DUAL Audio: subtitles and audio out of sync
By alina in forum ffmpegX general discussionReplies: 6Last Post: 26th May 2007, 15:16
