hi all! sorry my english![]()
somebody know what happen if i try use dvd-r burn in USA (in my computer) in Brazil(south america)
What's mean region 1,2,3,4???
is because the color? NTSC, Pal-M or other thing??thank you
different regions means that they can only be played on vertain areas..
america is region1, uk is 2.. -
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Region Countries
0 No Region Coding
1 United States of America, Canada
2 Europe, including France, Greece, Turkey, Egypt, Arabia, Japan and South Africa
3 Korea, Thailand, Vietnam, Borneo and Indonesia
4 Australia and New Zealand, Mexico, the Carribean, and South America
5 India, Africa, Russia and former USSR countries
6 Peoples Republic of China
7 Unused
8 Airlines/Cruise Ships
If you are looking to remove the region encoding the only way I know how to is to rip the DVD to your computer first using Smartripper or DVD Decrypter and making sure you select for the program to make the DVD region free.
Hope this helps -
If you have an authored DVD-R then it is not region protected (region 0). You cannot have region protection (or CSS for that matter) on a DVD-R, nor do blank DVD-R's purchased overseas have region protection.
If you have a DVD-R burner that you purchased in the US, you will probably be able to switch regions on it. You can normally only do this 5 times though (but can be disabled with firmware). The easiest way to switch is to stick a commercial DVD into your drive and try and play it with PowerDVD...it will ask you if you want to switch the region of your drive.
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 13:58 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 22:35
