  1. I was trying to use this program to convert a avi file to vcd, but when i go to source range i have nothing but a blank screen, but the audio lines show up, i have tried 3 different files and each time i get the same problem. I did watch the file using divxplayer2.0 alpha and they video and audio is fine, should i go ahead and encode the file or is something wrong. Can somebody please help me? thanks
  2. Make sure on the main window that under "Stream Type",...
    "System (audio /video)" is checked.
    "Today is only yesterdays tomorrow"
  3. tmpegnc doesn't convert my mpeg file to *dat
    which means i can't create a vcd file
    help!
  4. Naver,
    TMPGE > Setting > System > Mpeg 1-vcd or Mpeg 2- svcd ,etc.
    (sorry cyke 1 ,this is actually your thread)
  5. i made sure that was checked, and went ahead and encoded the file all the sound still now video.
  6. go ahead and start the encode for a few seconds then stop it.
    you can then try and play back the little clip.
  7. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    If your not getting antything but black or blank screen ..even as it encodes..
    Then try ...Go to option>enviromental settings>VFAPI plug in....and right click on the AVI vfw reader...select higher priority a couple times...to increase its prioity..(repeat for the avi2(dml) file reader) ..That should help.
