Hi I hope someone can help me. I am am having trouble playing back movies that I have downloaded from KaZaA. I am using TMOGEnc to convert the AVI files to a mpg. Then I am using Nero to convert them to a VCD. The problem lies in this the VCD seem to play ok on my computer but when I go to play them on my DVD player ( samsung 711 ) some that I burn play others don't or they don't play then after loading/unloading/loading them they seem to play or even play then stop in the middle????. I have been burning them at 1x the slowest i can and I have checked my player does support VCD play back . Does anyone have any idea what i need to do to get them to work most if not all the time ???
thanks Frank
First make sure your making fully compliant Mpeg 1's, do this by loading a PAL/NTSC template in TMPGEnc.
Next don't use cheap CDR's, Your player may not like the brand your using, try Maxell or TDK -
Where do I get a pal/NTSC template also I tried using the cd i made in a friends dvd player and they worked fine. The quality was not so good ( any hints on improving this ) but I will try a different cd maker I was using Acer cd's I'll try something a bit better.
Thanks -
The VCD templates are in TMPGEnc "Template folder" Click the load button to load one
Samsung BD-P1500 not playing BD
By joslyn42 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Jan 2012, 02:12 -
Samsung Blu Ray Player BD P3600 inconsistent in playing back copied DVDs
By ibramson in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Nov 2009, 18:36 -
samsung 1080p9 wanna play rmvb movies
By phantomeduke in forum Video ConversionReplies: 1Last Post: 29th Jul 2009, 13:50 -
samsung p390 playing usb drive
By aajmac in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2009, 21:34 -
Samsung DVD-1080P7 - Not Playing Widescreen
By kokaine in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Nov 2007, 11:13
