Results 1 to 13 of 13
  1. Member vhelp's Avatar
    Mar 2001
    New York
    Evening all.
    RE: ESC K7S5A - and Lost CD-ROM access
    Every time I put a CD in either my DVD-ROM or CD-ROM, no files show up
    in explorer, and I also get the Retry / Cancel buttons
    I can't even try to re-install the drivers on the CD because I have no
    access to the CD-ROMs. Now, during my system booting up, I can see
    it senses and finds the CD-ROM and DVD-ROM drives, but once Windows 98
    is up and running, I have no access - they don't exist.
    I'm not sure how this happend. I thought, at first, that maybe I made the
    mistake and startup up a driver app (after D/L'ing a 4in1 driver that a
    user had pointed out in a previous thread, then later canceled) I am not
    too sure if this caused my CD-ROMs to disapear forever - or is it the cause?
    Ok, everything was working fine up to this afternoon, when I lost it all.
    So, maybe it was the 4in1 driver I started up by accident.
    Anyways, I'm looking for a driver for this board to get me back my access
    once again. I've tried visiting www.ESC.com and www.ESCUSA.com and
    ESC Elitegroup, etc. but none of them have the drivers for the K7S5A.
    Was this MB that good, that it didn't need any updates?
    Well, anyways, I hope this was the right area to post, as there is no area
    for hardware etc.
    -vhelp
    Mar 2002
    canada
    not sure if they have what your looking for,but you can try this: http://www.driverguide.com/
  3. Member vhelp's Avatar
    Mar 2001
    New York
    tenders,
    they didn't even have a match for "K7S5A" - oh well.
    Thanks just the same.
    -vhelp
  4. You could try to remove it from your hardware profile and then allow windows to redetect it. Windows always has default drivers that will get it working, even if only to read a disc. Then you could use it to reinstall its own native drivers.
  5. Member vhelp's Avatar
    Mar 2001
    New York
    devinemi83,
    that's very funny! I was just about to do it, when your post came in.
    I had just remembered doing something like this once before. Well, we'll
    see what happens in a moment or so.
    Thanks all.
    -vhelp
  6. Good luck
  7. Member vhelp's Avatar
    Mar 2001
    New York
    tanx.
    I'm about to sign off - siranira!
    -vhelp
  8. Member vhelp's Avatar
    Mar 2001
    New York
    Success!
    In short, I ended up having to re-install Windows 98. Luckly, I had it on
    my harddrive. Else I wouldn't have ben able to load it. I had no access
    to my CD-ROM drives via any kind of *.sys driver, etc.
    I knew I had a good reason to put a copy of my CD-ROM's Windows 98
    on my HD. Yeah!
    Oh, so far, my CD-ROM drives are back as well as my HDs too.
    Thank you all to those that responded.
    The End
    -vhelp
  9. next time try a scanreg from dos mode.. that worked almost all the time back during my win98 days
  10. it's ECS not ESC
    Jul 2002
    Erie, PA United States
    Try this link: http://www.ecsusa.com/ecsusa/www.ecs.com.tw/download/index_driver_k7s.htm
    I'm a little late in posting this since I just came across it, but the K7S5A is based on the SIS 735 chipset. Downloading and installing the VIA 4in1 drivers more than likely totally screwed things up since it was only intended for VIA based chipsets.
  12. kayfam:
    It's based on the SiS 735...
    I know because i had to download new sound drivers to get XP Pro to work with AOL because everytime the guy said Welcome! It shut down my pc...lol
    Jul 2002
    Sorry my fault....I meant the 735. I edited my original post to reflect the same
