also when i change avi into vcd the finish is very blocky whould it make a difference if i downloaded divx files and changed them insted to vcd? also is divx an extension or is it a name e.g myfilm.divx or myfilm(divx).avi any help appreciated
DIVX is a form of compression. AVI is a video format that when uncmpressed is enormus. A 1 hr movie would span several GB's. A DIVX movie will have the extension .avi but the video and sound have most likely been compressed. The benefit of AVI is that you can use "CODECs" to compress both the audio and the video with a program like virtual dub. DIVX slightly reduces the quality but the resulting file is sometimes ten times smaller than if it were uncompressed. So when looking fo DIVX look for moviename(DIVX).avi Also converting from DIVX to MPEG is not easy make sure you follow the howto guide exactly.
Whats the difference between these 2 MKV files?
By dave in or in forum Video ConversionReplies: 2Last Post: 11th Aug 2011, 16:44 -
Is There Much Difference Between Quantizer 1 And 2 In Divx?
By Anakin in forum Video ConversionReplies: 8Last Post: 17th Apr 2009, 16:12 -
Divx or xvid? Whats the difference?
By szalaikornel in forum Video ConversionReplies: 3Last Post: 17th Jan 2009, 13:16 -
SWF mx, swf 3 ( legacy ), and FLV, whats the difference
By theewizard in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2008, 00:15 -
difference between DivX and Xvid?
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 20th Sep 2007, 06:07
