I have been at using ffMpeg for 1.5 months. Started with 0.0.2 and am now using 0.0.3. I know there are others out there who have had success but from my standpoint, it just doesn't work.
I have tried every preset. I have gone through every combination of settings for audio and video. I still can not get the audio and video in sync.
VLC client plays the ripped DVD VOB in prefect sync. When ffMpeg converts the VOB into a .MPG file it is immediately out of sync.
I have posted before and major has tried to help me but we have not had any success. I am even up for some out of the box type ideas like maybe my hard drive needs to be defragged, I know that is an issue on the PC side.
QT doesn't play ffMpeg MPEG-1 files smoothly either and neither does VLC client. They are choppy.
Since VLC plays the ripped VOB perfectly I know the problem must be somewhere in ffMpeg.
Does anyone have any ideas ?
-S
Results 1 to 10 of 10
What Kind of machine are you using? I've had similair problems on my white dual usb ibook. I have just tried my first rip using the latest version. As usual I set my sampling rates, both audio and video, to the rates shown in ffmpeg for the source. I also cannot get the mpleg file to play smoothly or at all. To see if it would work when burned to a VCD, I burned it and played it on the DVD player. The video would have a hiccup like pause every 7 to 10 secs; and the audio was way out of sync. I also had the interestin error message while creating the VCD with VCD builder, the the audio was sampled at 48,000 hz, and should be at 41,000.
So how are people getting this to work? I've downloaded VCD and SVCD files off of several newsgroups. All of these downloaded files play smoothly in VLC. So what is the issue? Why do the mpg file I create with ffmpeg not play smoothly, and why are they not in av sync/
RRandolphK
I would say that the "hiccup" is because your bit rate is set too high. Try 1,500 for VCD. Any less will look bad. Also, try hitting pause and play again on your DVD player. That sometimes fixes a "temporary" unsynced problem.
I have a G4 450. I don't know the answer to the synch problems. I have been trying to make a VCD from a DVD since Nov 2001. Lets just say that I have made several hundred coasters.
I thought that ffMpeg was the answer and it is 1/2 of it. Once you get your bit rate settings down the video that it creates looks beautiful. It is the audio that is the problem.
I don't know the answer, I am hoping that someone can help.
-S
I had this same problem, and oh was I feeling stupid when I figured it out. My ripped file from dvd SAID it was at 29.97, but in reality it was really playing at 23.97. After a few tries with several different movies I knew for sure this was the case. Bad frame rate... Hope this helps.
Not a solution but the same problem.
When I create a VCD from a VOB in FFMPEGX using the "Quick Presets" the audio skips ?
I got an error message while encoding that said audio was at 48 and should be 44.1, so I tried that but it has the same effect.
I used the presets bitrate of 1150 for video and the audio bitrate was 224
The VCD works in my player but audio sucks.
ANyone have any ideas or info on how to create a VCD without using FFMPEGX ?
thanx
I found this on VCDhelp
New Improved Easy Mac DVD->VCD
http://www.vcdhelp.com/forum/userguides/88944.php
Sorry for multiple posts.
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 05:11 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 06:09 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
Difference between ffmpeg -threads and ffmpeg-mt
By Calidore in forum Video ConversionReplies: 2Last Post: 7th Mar 2010, 23:44 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 03:55
