If any one has any knowledge about.... I'm using wintv2000 to capture @ 6mbps (mpeg2) to a NTFS partition. I'm running Win2k, At the 4 GB mark wintv splits the file,which is great if you cature to a Fat32 partition. but I am no longer hampered by that. does anyone know a registry tweak or whatever, to enable wintv to make the file one large one??
any feedback would be greatly appreciated!!
Thanxs in advance
"The software said Win XP or better, so I Installed Linux"
http://www.shspvr.com/tweak/pvr880/tweak.html
read whole pageWhere I walk, I walk alone. Where I fight, I fight alone. -
here is a link and the discription-
"This update makes it possible to capture unbounded files MPG of size (which was of 4Go). It is necessary to capture your file on a hard disk or a partition with format NTFS. You can for example have Windows XP installed on the disc C in FAT or FAT32 and capture on the disc D formatted in NTFS http://www.hauppauge.fr/sup/drv/pvr_1.6.exe"
this is the link to the entire page-
http://translate.google.com/translate?hl=en&sl=fr&u=http://www.hauppauge.fr/sup/driver...UTF-8%26sa%3DG
read everything before you use to make sure it is correct for youWhere I walk, I walk alone. Where I fight, I fight alone.
9gb .ts > 4gb .mkv
By NotSoEasy in forum Video ConversionReplies: 28Last Post: 5th Mar 2012, 21:21 -
help -- salvaging a 4gb avi file
By pkpara in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2009, 21:50 -
convert DV to 4GB file
By bensonlo in forum Video ConversionReplies: 3Last Post: 5th Mar 2008, 16:15 -
4gb Limit on SDHC Card, FAT32
By AVCHD in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 05:24 -
About 4GB Memory
By mn072065 in forum ComputerReplies: 8Last Post: 30th May 2007, 05:31
