Hi gang. Couple of questions below.
1. I've been pretty good at making VCD's with chapters using the Sefty's Guide. Last night, I wanted to make a SVCD of Lord of the Rings on 3 CD's. I'm uising TMPGEnc and encoded the movie in 3 parts, 750mb each, using CQ of 75, with the high bit rate of 2400 and a min of 300.
I used Chapter X Tractor to read the IFO and pasted the info into VCDEasy, but VCDEasy said "number of possible chapter entry points:1".
Is it because I made a non-standard SVCD?
2. I've tried using TMPGEnc and the SVCD template for NTSC, but when I click on start, no encoding takes place for VBR. If I change VBR to CQ, then it works and begins to encode. Why??? Do I have a defective template? I'm using TMPGEnc Plus version 2.53.35.130
I found the answer to #2 hehe. VBR does not encode right away. It does it passes first before encoding. I also discovered that VBR can take twice as long to encode a movie, so I'll stick with CQ, but I have not found an answer for question #1:
How was this video made ?
By surferadi96 in forum EditingReplies: 5Last Post: 16th Mar 2012, 09:31 -
Where Are these Ritek CD-Rs Made???
By NBK2 in forum MediaReplies: 19Last Post: 19th Aug 2010, 14:32 -
Add chapters (at least) to already made DVD
By tge101 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 14:16 -
How do you insert chapters into mkvs that you've already made -rtango?
By yoda313 in forum Video ConversionReplies: 2Last Post: 29th Mar 2009, 09:16 -
Best Purchase Ever Made!
By illpeeonu in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 18th May 2007, 20:56
