I have used TMPGE and serveral other similair...
but am looking for the easiest one to use for making videos(highlights) of MPEGs i have
i can edit the videos fine in what im using but it will only let me put one sounrce of sound on...whereas i would like to have at least two sound sources on my videos and the ability to fade the sound in and out of the movie...
can anyone reccomend one that will aloow me two channels of sound???
and one for editing the sound on an mpeg as well so i only get the sound???
treelo,
I use Uleads Video Studio. I have both version 5 and 6. These are excellent programs for editing. 5 allows one audio and one voice; 6 allows 2 audio tracks and a voice as well as two video tracks. Very simple to use and I think 6 allows you to edit the music or audio as well (just got 6 so i'm still learning it).
you can get a demo here,
http://www.ulead.com/vs/trial.htm
good luck. -
Ulead is good if you want a decent lower price program that is easy to use.
If you want a high end product I recommend Sonic foundrey's Vegas Video 3. It has everything and anything you could want. It also allows infinate video and or sound tracks. Not that your going to need that many. LOL
Its intuitive and easy to use and at the same time is as powerful as any of the other professional video editing programs around.Not only am I perfect but I'm Canadian too!
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
Edting DVD high qualty
By niels_m in forum EditingReplies: 1Last Post: 9th Oct 2008, 09:41 -
DVD > AVI or Mpeg fo re-edting then burning to DVD
By nutshellml in forum DVD RippingReplies: 7Last Post: 31st Mar 2008, 10:12 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45 -
DVD creation/edting with VISTA
By ronkleim in forum Authoring (DVD)Replies: 6Last Post: 27th May 2007, 02:07
