I don't have a DVD player on my computer, but if I burn a VCD, will I be able to play it on my computer? Do I need some special software or something? Thanks
I have another problem. I was using VCDEasy, I added the first mpeg file, and it started scanning it, and at the end of scanning it, it gave me this error:
"(smr)signs-tc(1of2).mpg"
Unknown encoding frame rate: 60 -
Why burn to VCD at all if you're going to watch on your PC? I'd use DiVX to encode. You'll get much better quality and a smaller file using DiVX as opposed to VCD (MPEG1).
i agree. go with divx
but you can watch a vcd with powerdvd or windvd if it installs and vcd is on harddrive. my svcd plays through my cdrw drive(and yes i just tried it) so its your choice.Where I walk, I walk alone. Where I fight, I fight alone. -
And why does it give me that error? You want me to convert it to DiVX? Sorry, really new to all this.
DiVX is a newer form of MPEG compression. It can compress files much more efficiently than MPEG2. You can easily fit a 2 hour movie on to a single CD-R with DiVX while maintaining excellent quality. Check out the 'CONVERT" section for more info.
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 13:36 -
Newbie codec question
By fotoruss in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 22:47 -
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 11:57 -
Newbie question about cd music
By justalice in forum AudioReplies: 4Last Post: 7th Apr 2008, 20:08 -
Newbie Networking question
By karl333 in forum ComputerReplies: 1Last Post: 5th Mar 2008, 13:23
