I've been having a problems with VirtualVCR. I like the program I was wondering if anybody could post their settings. One of the problems I have is Audio/Video is out of sync. Second, I really need to know a guide or settins of how to setup the codec piece. I captured an avi file using Picvideo for about 1 min and the size was about 256mbs. So if anybody knows a successful guide like the one posted in vcdhelp "How to Capture with Virtualdub" but with VirtualVCR I would appreciate it.
I would like to know the same? I would like to know the optimum settings for this to copy Hi-8 to DVD-R. Do I use a codec for the AVI capture? If so are they built into VirtualVCR, because they show up in a popdown? What is the best free one (besides huffy)?
Clif Smith
AMD XP1900, 512ram, 100 gig drive. ATI All in wonder card, Pioneer DVR-103 DVD burner. -
I use this all the time. I'm at work and will look at some things when I get home... I've had no trouble with it....
My best experience with Virtual VCR is to use the Morgan Media codec, I have 2. One captures about 200mb in 1 sec the other capture about 60mb in 1 sec, which is the one I use (Think its called Morgan media mpegJ codec or something similar, I'm not at my capturing machine right now). I then change the quality from 75% to 90% and capture at 640x480. Really depends on what you want to do with the end product. I have being encoding it with TMPGEnc then saving to SVCD CD-R's using Nero, works pretty well. I also check the "Re-sample audio to match video" under the AV Sync tab.
rhuala -
When using VirtualVCR, as a previous post indicated, check the "Re-sample audio to match video" box in the AV sync tab. Also the quality of you sound card affects audio sync. A cheap sound card might not be able to keep the sync with the video capture card. I use VirtualVcr and a AverTV Stereo TV tuner card and I can capture hours of video straight with no problems with audio/video sync. I also use the picvideo mjpeg codec, click on the properties box next to the field where you select the codec and change the quality setting to 19.
El_Seed or anyone,
Can u get the timer function to perform properly. I don't know if it's a problem with VirtualVCR or Windows but everytime I set the timer it says it succeeded yet no capture occurred? I am setting it up using the Task manager as described on the web site. Any insights would be helpful. Thanks.
rhuala
---system---
Windows XP Pro
AMD 1700+, 512MB RAM
MSI Geforce 4 Ti4400, Latest detonator drivers
Creative Soundblaster Live
MSI K7T266 Pro2 Motherboard, Latest 4-in-1 drivers
60GB Hard Drive, ATA66
Little setting problems with VirtualVCR
By Greycat in forum Capturing and VCRReplies: 10Last Post: 28th Jul 2015, 18:07 -
VirtualVCR Tweaker
By Torrential in forum Capturing and VCRReplies: 1Last Post: 21st Apr 2010, 04:24 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 09:46 -
VirtualVCR help
By LittleJimmy in forum Capturing and VCRReplies: 3Last Post: 11th Jan 2009, 23:34 -
VirtualVCR and ATI TV Wonder
By moorthy in forum Capturing and VCRReplies: 1Last Post: 28th Sep 2007, 18:46
