Hi !
Iam more or less new to this all but i managed to make from an Divx file with AVI2SVCD 2 images which i burned on CD . Everything worked fine for the first CD - but on the half of the second CD the Audio is like 1 or 2 seconds to early . This happens as well if i just use Tmpegenc . I probably could manage to change something if it was about all the video ... but it just happens on the 2nd half of the film more to the end . The DivX is playing fine without the audio problems ...
Thanks already for the replys ....
Ok here some more information - the audio seems to be MP3 .
when i extract only the audio with VirtualDub then i get a length of 84.14 Min . But when i look in the file information of Virtual Dub for the whole file it says it is 1 hour and 29 mins and 14 secs . But it isnt that much out of sync .
An other thing i noticed is that Virtual Dub says in order to make audio and video sync it will need a framerate of 23.977 . But Avi2Svcd wont support that it says .
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
