I want to save some VCD disk on my hard drive for storage and for burning at a later time. Is it okay to copy the dat file and saving it directly to my HD? Can I just re-name the file as an mpg?
I'm able to play both file types on my system w/ zoomplayer, even after renaming the dat to mpg. I know they're not the same since the file sizes appear different.
Is it a good practice to re-name files? I plan to use Nero to make VCD disk and will drag my re-named Dats (now mpg) on to the new VCD window. I don't plan to convert these to other formats, ie SVCD or Divx.
I know VCDgear is available, but is seems faster just to copy the dats and rename them rather than have VCDgear convert.
Any insight would be appreciated!
Yes, .mpg is the same as avseq01.dat on a vcd, rename it
"We who are truly brave will never live in fear"
7 Time WWE Champion, The Rock -
Rename anything like this, and you wont fool the programs. For what you want to do, you could add the .dat file as it is without renaming it. There is a header difference, but Nero wont mind a .dat file anyway.Originally Posted by EatMoreChickens
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 04:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 11:25 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 18:06 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 06:19
