1) when i try to convert from avi to vcd. how come the video source that i have isnt the following:
NTSC if the video source is 29,97
NTSC Film if the video source is 23.976
PAL if the video source is 25 FPS.
it's something like 12.500fps. so which one should i use?
2) after i burn this movie to cdrw, and watch on my dvd, the screen keep skipping? how can i fix this
can anyone help me?
it is at 12frames per second because that is how it was when you dl it. it probably jumps and skips on your dvd because it isnt compliant but I am not sure because you haven't given any other info.
at 12.5 frames per second you can simply double it to 25 fps...i.e. PAL. Each frame will display twice but it will look as good (or as bad) as the source. If you have some good software, you can try to interpolate between the two frames to make things smoother....I'm not sure what you could use to do this though (probably something like Aftter Effects would do the trick though)
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 08:38 -
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 10:47 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 02:54 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 11:34 -
Need someone who has seen Transformers The Movie(animated) to answer Q?
By Denvers Dawgs in forum Off topicReplies: 10Last Post: 27th Jun 2007, 20:42
