The compatibility list shows it has vcd capability. Cannot locate the manual. Also tried to call Sony's tech support. No help. Anyone know how to play vcd's on this sony? I am certain the vcd is good because it plays in a pioneer dvd player and a phillips dvd player.
de
What media did you use (CD-R or a CD-RW)?
On my Sony, I have to use the STI brand of CD-R's from Circuit City for VCD's to play on my Sony DvD player. A CD-RW should work in your Sony for VCD playback. -
I just used cheapo PNY's. Do you have the same dvd player? Is there anything in the manual that explains how to play VCD's (setting, etc) or do you just put it in and it plays?
thanks for the help.
de -
Nothing worked in my Sony except for the STI brand media from Circuit City. It has a higher reflective coating than other brands. It was the only brand that worked in my Sony DVPS530D except for CD-RW's.
The display should identify your CD when inserted. It should say VCD on the display. Then simply press the play button to begin. -
it says No Disc. thanks for the tip on the media. I may try some different brands.
de -
It may say it plays "VCD" but that is not the same as "CDR/VCD" Commercial VCD's are not made the same way as we make themOriginally Posted by de8212
This site lists it, but it has no "CDR"
http://www.techtronics.com/uk/shop/50-sony-dvp-s360-360-multi-region-dvd-player.html
But this one is listed as having CDR/RW (NS400)
http://www.techtronics.com/uk/shop/50-sony-dvp-ns400-multi-region-dvd-player.html
Sony DVP-SR200P -- Playing CDs In Repeat Mode Without a TV
By maico996 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Jun 2012, 15:57 -
Region Hack for Sony DVD DVP S360
By Lenfid in forum DVD & Blu-ray RecordersReplies: 4Last Post: 31st Dec 2011, 19:17 -
Success creating and playing AVCHD discs on Sony BDP-S360 (BDP-BX2)?
By wwaag in forum Authoring (Blu-ray)Replies: 25Last Post: 3rd Mar 2010, 14:18 -
Sony DVP S360 DVD player - No DISC problem
By weenie02000 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 5th Aug 2009, 09:43 -
Sony DVP S360 DVD players - No DISC ERROR
By parmar in forum DVD & Blu-ray PlayersReplies: 16Last Post: 14th Dec 2007, 10:44
