  1. i'm using TMPGEnc to encode a 2:30 hour movie and it takes
    my PIII 500 computer 15 hours to encode it.
    am i doing something wrong or is that how long it takes?
    thanks for the reply
    Aug 2001
    austin tx
    mars,
    I have a P3 1ghz system and mine takes about the same time. Your most likely doing it correctly it just takes a frkn lifetime to rip one. Especially that long of a movie.
  3. mars,
    I have the same comp and 15 hours is the time you spend on average quality SVCD.
    Once, I tried to set up everything best, it took 38 hours.
  4. that process is pretty normal, i have 1300athlon with 256mb and mine take 5 to 6 hours, one thing i have read is that you can clip and resize the movie and take away the black bars around the movie
  5. get dvd2svcd
    this will
    a)look better
    b)take less time
    just what you need!
