    Jul 2002
    Hamilton, New Zealand
    Help, I am using adobe premiere to edit mpeg clips.
    But when i export with the LSX-MPEG plugin the audio is either out of sync, or has a quite clicking noise every few seconds.
    The video I am importing is mpeg1 video with 4,4100hz sound muxed together. I am exporting the sound as 4,8000hz mp2 audio muxed together with my mpeg video, so later on i can demux it and author to dvd.
    Is there any way to stop this?
  2. Thought I'd just post here instead of starting a new thread.
    I can't seem to get Premiere to offer mp3 as an audio compressor when exporting video.
    Any help?
    Apr 2002
    The State of Frustration
    What are you using to actually convert? If you like, Gold Wave has a Pop/Click in the Effects menu. Maybe it can help as well. Or you can load your video into VDub, select File-->Save wav..., and use this audio as your audio input.
    Hello.
