how can i join 2 clips using TMPGEnc?
i can select 1 clip and cut it but it wont let me to select 2 clips and combine them.
HEEEELP PLZ
Why use TMPGenc to join?Much better is Video Tool.Look to your left for the program
To join in TMPGEnc, all you have to do is load all of the clips you want joined (just keep clicking add and selecting the files you want), then specify an output file at the bottom, and click "Run".
Can you JOIN two FLVs?
By r2997790 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 04:04 -
how to join 2 video_TS
By hilario in forum EditingReplies: 2Last Post: 6th Oct 2009, 17:33 -
Join IE6NOMORE ?
By lordsmurf in forum FeedbackReplies: 0Last Post: 1st Sep 2009, 07:19 -
TMPGEnc 4.0 XPress- Join video losslessly
By ranosb in forum Video ConversionReplies: 2Last Post: 30th Aug 2009, 14:00 -
Join two partitions
By Jomapil in forum ComputerReplies: 5Last Post: 11th May 2009, 17:28
