Having a problem burning VCD's. I am able to burn the first cd of any movie but for some reason when I try to burn the second cd it can't be done and I have tried with multiple programs.
I start out by ripping with SmartRipper and then loading the vob files into DVD2AVI. I then encode with TMPGEnc by loading the d2v as the video source, the AC3 wav as the audio and I use Pinoy's VCD template and set the source range to split the movie for 2 discs. After encoding I use VCDEasy to burn and as said I am able to make disc 1 but not disc 2. I use the exact same settings for both (except the source range of course) but nothing seems to work......Any ideas???
Also note that I can load the image that VCDEasy creates (bin file) into Daemon Tools and play it and everything seems ok, I just can't get any burning software to burn it.
