I have my mpeg2 file, looks and sounds great, no synch probs.
I use ulead dvd moviefactory, and burn it to apple dvd-r, and gradual synch problem gets pretty bad by end of the film.
what is up?
Andy![]()
is it the software i am using (ulead?)
actually, that can't be it, I have successfully done this with home videos.
is dvd maestro really a lot better? -
i was about to post about the same problem.... i wanted to no though is workshop better and does it have the same sync problem?????? i just went to the site and looked... they have a " Audio/Video Synchronization Patch " patch..... try that and see if it work.... i wont have time till i get home from work tomorrow
i just d'ld it, i will try it now, and post the result in a bit.
Andy
ps-thanks for the info -
Here's another audio sync conumdrum I'd like to share. I burned lots of DVD's using DVD Complete and have had no problems with syncing until I tried to burn one about 2 hours long. The audio is fine until the last 5-10 minutes then it gets out of sync by about 1/2 a second. I've had 2 different burned DVD's (different content) do this. It's really annoying when the lips don't match when they're speaking.
I capture using Sony's DVMC-DA2 Analog to DV Firewire box in the DV codec using Microsoft's Movie Maker. Then use TMPGenc Plus to edit and encode to MPEG2. I merge several clips together (music videos) into one long clip that's about 2 hours also using TMPGEnc. From what I can tell, the merged MPEG2 is synced up at this point.
I then use Dazzle's DVD Complete to author the MPEG, creating menus. When I do import the MPEG into DVD Complete, it has to convert the audio. When I've finished authoring, I've used both DVD Complete and Nero to burn and still get the same out of sync result.
So, the coverting of audio may be the problem there, but is there a way to get TMPGEnc to make the audio up to DVD (or DVD Complete's) specifications? Does any other authoring program have to convert the audio like DVD Complete when using a TMPGEnc encoded file? Any other users of DVD Complete have this problem?
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 14:23 -
Probs re-encoding VC-1 codec....
By runLoganrun in forum Blu-ray RippingReplies: 8Last Post: 3rd Feb 2010, 23:27 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47 -
audio synch
By Usagi in forum DVD RippingReplies: 5Last Post: 28th Dec 2007, 19:11 -
Audio goes out of synch
By Semaphoric in forum Authoring (DVD)Replies: 3Last Post: 27th Sep 2007, 22:01
