I have been able to capture video and audio from my VCR with my Asus V7100 Deluxe Combo card. I have edited the video and am also able to display video and audio to a standard TV set. When I try to record to VHS tape nothing appears. I have tried connecting the cables directly to the VCR(audio and video in, as I have done on the TV set) but nothing records. I have succeeded once to capture audio to the VCR, but cannot remember the exact combination of connection.
Can anyone help?? Thanks in advance
Can anyone please help with this, I really need help with this asap and can't seem to find any info on how to do this on this site.
Thanks again!
I believe you emailed me, but just incase i'm wrong, when you connect your Asus to the VCR, make sure you are using the Video/Audio IN, and also remember to set your VCR to the AV channel, and the TV to your VCR viewing channel, that way you should be able to see even prior to recording, the PC on your TV, once you do, just press the Record on the VCR, and you should not have any problems.
NOTE: Check that the Output from your PC (PAL/NTSC) will match what your VCR can record.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
recording test pattern on a vcr from PC
By mammo1789 in forum Capturing and VCRReplies: 11Last Post: 13th Apr 2012, 10:59 -
Need LG897T dummy instructions on VCR recording
By Astrovel in forum DVD & Blu-ray RecordersReplies: 5Last Post: 7th Mar 2009, 00:45 -
Recording in VCR Mode
By mapmaker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2008, 19:23 -
HDTV VCR recording, VHS TAPE?
By jb66 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2008, 18:45 -
What is the exact physical point where recording happens vcr and a tape ?
By arturock in forum Newbie / General discussionsReplies: 5Last Post: 9th Sep 2008, 22:15
