Hi,
I've noticed that DVD rips tend look much darker than the original clips on DVD. Why? I realize there are tradeoffs because of the reencoding.
This has nothing to do with Macrovision because those DVDs are not Macrovision-protected. Whether I use De-Macrovision option in SmartRipper or not, the result is always the same.
Is there anything I can do about this annoying problem? Some rips are simply too dark.
Thanks.
Depending on the encoder you use, you can always experiment with the with the filters to adjust the brightness, contrast, etc.- "Simple Color Correction" under the "Settings > advanced" tab in TMPGEnc, or if you are using CCE, you can frameserve through VirtualDub and use it's filters - "Video > Filters > 'add' button > Levels"
You can't fool me, I'm a moron! -
Originally Posted by tamgiao
When converted and played on a DVD they may look OK again
Darker label with Lightscribe
By omega_weapon in forum MediaReplies: 9Last Post: 26th Apr 2011, 18:53 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 12:52 -
Clearest DVD Rips
By dudeman316 in forum DVD RippingReplies: 38Last Post: 18th May 2009, 08:33 -
WinDVD8 unlike 4 gives darker picture
By DBenz in forum Software PlayingReplies: 0Last Post: 18th Jan 2008, 17:31 -
Flash videos look darker after encoding
By DVinci in forum Video ConversionReplies: 2Last Post: 30th Jun 2007, 00:35
