I have successfully encoded a MPG from Divx using TMPGEnc. After burning it to a CDR using Nero, I notice that the picture 'hops' slightly during play back (Sound is fine & Divx doesn't hop either). Is there anyway to smooth this out? Can become anoying when watching a movie. I have used the guide on VCDHelp website for settings for TMPGEnc to convert to VCD.
Any Help would be grateful!![]()
Results 1 to 9 of 9
What settings ?
Did you load a VCD template and make a standard compliant VCD ? -
Is the "hop" regular, like every second or so, or does it seem like there are frames missing, like jerky movement when the camera pans?
Answers as Follows:
King John: I haven't used a Template in TMPGEnc. Just followed Guide from 'http://www.vcdhelp.com/tmpgenc.htm'. Should I be using a Template? Let me know & if so what settings!
MH2360: The 'hoppin' is jerky, like missing frames. Have just downloaded VirtualDub to check Source Divx. Just a hunch I'd thought of, but could problems be I am trying to encode a PAL VCD from a NTSC Divx?I know NTSC has more FPS than PAL. This would explain the jerkiness! Will check this out & get back to you!
When i try to convert 23.976 fps Divx files with the NTSC film template, i get jerkiness like you describe. I use the Settings/Advanced/Inverse Telecine function in Tmpgenc, it smooths things out nicely. Use source range to encode an minute or two (it takes a while for I/T to set itself up for a full movie).
BTW: Encoding a PAL file with an NTSC template will most definately cause jerkiness.
Originally Posted by MrBlack&White
mpg to vob conversion without re-encoding
By dalek6388 in forum Authoring (DVD)Replies: 4Last Post: 22nd Nov 2010, 16:04 -
Probs re-encoding VC-1 codec....
By runLoganrun in forum Blu-ray RippingReplies: 8Last Post: 3rd Feb 2010, 23:27 -
Divx Author 1.5 Re-encoding standard divX files
By ejai in forum Authoring (DVD)Replies: 2Last Post: 9th Jul 2008, 19:28 -
mpg/divx --> 3gp anyone?
By trancer_84 in forum Video ConversionReplies: 7Last Post: 6th Nov 2007, 10:32 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56
