No matter wich file and settings I'm using in CCE, I allways get an error message when I try to encode: Read only 0 bytes, while expecting 8 bytes. I've had had this problem with both CCE 2.62 and 2.64, how can I solve this?
I guess your trying to encode from an .avi file source?
Well try this. Load the .avi file into virtual dub. In both Video & Audio menus select "direct stream copy". Then goto File > Save Old Format Avi".
Use this new file to load into CCE.
Let us know whether this has fixed it. -
Wow! it really worked!
I guess I'll keep on doing it, but if there's a way to encode without this step then it's better, I just don't like the sound of 'Old Format' (what does it mean anyway?)
Anyway thanks, it really helped me. -
It will only do it on certain avi's and it seems to be a problem with newer versions of CCE - stick to 2.50SP and 99% will be fine.
Newer versions of CCE simply are worth the hassle imho. -
i am having the same problem.
i use:
-windows2000
-CCE 2.5
-capture with wintv go (i know it's not exactly the best capture card) to .avi
-use VD and "save old format .avi" with audio and video in direct stream copy
-drag and drop .avi into CCE
-attempt to encode and windows states that "CCE has generated errors and will be closed by windows. You will have to restart the program"
i'm at a loss for converting .avi to with CCE. any help would be greatly appreciated -
You can't fool me, I'm a moron!
how to encode?
By inject0r in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2012, 12:12 -
Only Split - no re-encode?
By bobmane in forum Video ConversionReplies: 2Last Post: 28th Aug 2011, 08:35 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Why do I have to Encode?
By gilamran2 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2008, 04:29 -
Re-encode to HD
By lotsill in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 11:03
