I think DVDX is a great program to rip DVD's. It makes it very easy. I can make good rips every time. I only have one problem. The audio is a split second off most of the time. Is there something I can do to correct this, or is this normal with DVD Ripping?
Would love to hear some feedback on this..THX
Lets Make Some Movies!
Have used to for VOB to AVI from hard drive, but used smartripper to rip DVD, did the forum say something about starting a second later or something
Easy ripping with DVDx 4.0
By Starbuck2010 in forum DVD RippingReplies: 41Last Post: 11th Dec 2013, 01:17 -
How do I fit a DVD on one VCD with DVDx 4.0?
By Xoanon in forum DVD RippingReplies: 5Last Post: 27th Apr 2012, 03:20 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
DVD to XVID using DVDx 2.20
By Immortal25 in forum DVD RippingReplies: 0Last Post: 2nd May 2010, 07:20 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22
