For a newbiw like me this would be beneficial. I just discovered how to use different templates like KVCD, but haven't experimented yet. I just wanted to know if there was a standard rule of thumb to make quality VCD's that aren't hugs files.
For example I just found out noise reduction and sharpening filters will help reduce file size. What are some other things as far as constant bitrate CQ settings etc.
Another experiment would be to defy the 224 kb/s standard for audio, as I would like to encode at say 128kb/sec for smaller size. Will this work? With KVCD the audio properties aren';t greyed out like they are with TMPGEnc's standard templates. Thanks.
Load Tmpgenc standard template, load UNLOCK template, save w/new name, modify away. In my opinion, IVTC, VBR, Bitrate Variations, and 128 Audio are the best areas to experiment with, and for VCD particularly, smoothing filters of which there are many. I like Smart Area Smoother for Vdub, I forget which of several filter packs it came with.
Try CCE as well for CVD or SVCD.
Best way to play 3D bluray video files while keeping the best quality
By mad555 in forum Media Center PC / MediaCentersReplies: 5Last Post: 16th Feb 2012, 03:48 -
Editing a MTS Files and keeping the original quality?
By PHNeedsHelp in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 19th Feb 2011, 13:38 -
Help with keeping quality for archiving my video files. Interlace source
By drewzor in forum Video ConversionReplies: 11Last Post: 8th Mar 2010, 19:32 -
re-encoding vid file for smaller size but keeping same format?
By WidowMaker in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 14:56 -
Help in making MPEG-2 files smaller with encoding
By screwed in forum Video ConversionReplies: 4Last Post: 20th Jul 2007, 04:23
