I have been ripping shows off of Tivo and splitting them into their video (m2v) and audio (m2a) streams. When trying to re-combine them using TMPG, it keeps saying that the format is invalid or unsupported. I am using the registered, full version of TMPG so it should recognize the MPEG2 format of Tivo streams.
Allow me add in this little tidbit. A friend of mine who is using the same Tivo streams as I am has no problem combining the streams in TMPG.
Also, consider this. If I use the simple muxer in TMPG, it will combine the files, but it says that there is an error with it. It will not support the MPEG file it outputs this way, but will play in WMP with the MPEG2 codec.
Am I missing a Codec or something? I am totally clueless on this one. Any help will be appreciated.
Results 1 to 1 of 1
Audio sync issues when combining videos from Youtube
By The Invisible Hand in forum EditingReplies: 5Last Post: 6th Oct 2011, 12:43 -
Combining 2 DVD's help
By rede96 in forum Newbie / General discussionsReplies: 2Last Post: 30th Nov 2009, 14:35 -
TS combining
By vassock in forum Authoring (Blu-ray)Replies: 7Last Post: 17th Jul 2009, 22:12 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 18:44 -
Combining Many Video_TS
By Dragon_985 in forum Authoring (DVD)Replies: 2Last Post: 30th May 2007, 11:20
