Here's the guide http://forum.vcdhelp.com/userguides/91597.php
I don't see the point of 2 of the steps to convert to VCD, as they seem unnecessary. I have successfully converted an AVI directly from TMPGEnc to a MPEG and then burned to a VCD.
If you follow the guide it doesn't make sense. Ok the theory behind Divfix is ok but you open the avi and rebuild the index but divfix saves the files as a (filename).avi.divfix.
Then in Virtual Dub (another unneeded step IMO) you extract the audio and save it elsewhere as a .WAV file.
Then from TMPGEnc you are supposed to merge the WAV just extraced from Virtual Dub and the video of the original AVI together creating a final MPEG. Problem with this is it actually doubles the size of the original AVI, and it renders the process of using DIVFIX since TMPGEnc won't recognize the .avi.divfix file that was supposedly rebuilt.
Just wondering if I am not seeing the purpose of the guide. Thanks.
Results 1 to 1 of 1
General Purpose Video Files
By AndyPerry in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2009, 22:27 -
How do I remove a bad frame from a video without VirtualDub or DivFix?
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 11th Dec 2008, 19:07 -
I need an all purpose converter
By warlock110 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2008, 21:06 -
Best all-purpose format for DVD rips
By studawg66 in forum Video ConversionReplies: 5Last Post: 3rd Sep 2008, 11:49 -
DivFix++ v0.30 won't open
By Bix in forum Newbie / General discussionsReplies: 3Last Post: 26th Jun 2008, 23:40
