Hey people,
I keep getting this error with CCE, although i have been using it to convert movies for the last few weeks.This is the first time i have been getting it.The film im wanting to convert is "High Crimes 2002" is it because it maybe a divx 5.x?
The error message is:
AVIFileOpen("C:\DVD Data\Movies\DVD-2VCD\AviSynth_Script_file_avs-vfapi.avi") : According to the registry the type of file specified in AVIFileOpen does not have the handler to process it.
Any help would be great - cheers guys
PS i have an Avisynth v0.3 installed,is this the correct one?
mr_rasta
A few questions first before we can have a go at solving your problem.
CCE version used?
Please post your AVISYNTH script.
I have no problems encoding DivX5 files frameserving them using latest AVISYNTH (2.04 from http://sourceforge.net/projects/avisynth2/) into CCE 2.50. I know CCE versions above this (2.62 & 2.64 but not 2.66 beta) have problems with .avs files and can only assume you must be using once of these versions as you have converted your AVISYNTH script using VFAPI to a pseudo avi.
CCE 2.50 will however load .avs files directly and is quite a bit quicker in doing so.
Let us know how you get on.
Annoying video/audio sync problem
By WebMaximus in forum DVD RippingReplies: 2Last Post: 12th Nov 2011, 08:59 -
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 14:43 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 11:31 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 13:53 -
Annoying blackscreen problem with AVS video editor
By in flames in forum Newbie / General discussionsReplies: 0Last Post: 5th Dec 2007, 00:10
