hi,ive bin following this doom9 guide 4 fitting dvd9 onto dvd 5 guide(4.7)
but,when i try 2 select dvd maestro from the drop down menu,it isnt there,even though i have installed it,i tried 2 update the config setting,but no availe,can n e 1 shed sum lite on this??
cheers
spida!
...... Maybe you should try the ifoedit instead, I found it easier to use:
http://mpucoder.kewlhair.com/derrow/ -
the drop down selection menu is for presets, not for installed software. you can create your own preset or use the ones already there. chapterXtractor does not scan for installed dvd/vcd/svcd applications on your computer
hey i've been following that guide from doom9.org too and i'm stuck on 2 parts...one is should i make more than one .chp file from chapterxtractor if my file has 4 different sections? (by sections i mean my ripped vob set has 4 different episodes and chapterxtractor only saves the .chp file with times for one episode)..and two...how do u get dvd maestro to convert your m2v file back into vob's?....the guide doesn't explain this.
Extractor Can't Find Subtitles?
By Phantoms Cry in forum SubtitleReplies: 3Last Post: 28th Nov 2011, 15:13 -
CC extractor
By tb582 in forum SubtitleReplies: 2Last Post: 9th Aug 2010, 13:56 -
An alternative audio extractor.
By A Traveller in forum AudioReplies: 2Last Post: 25th Mar 2009, 17:15 -
ISO extractor for Mac
By flvgordon in forum MacReplies: 3Last Post: 9th May 2008, 02:28 -
Remember extractor?
By Man Dat Ting in forum MacReplies: 3Last Post: 18th Aug 2007, 03:13
