Hi, I'm new to this VCD stuff, and was hoping someone could help me with my predicament. I've bought a VCD which has two audio channels ( one Chinese/one Japanese ), and I seem to be having trouble switching between them. PowerDVD plays them both together, but ZoomPlayer only plays the Chinese track. Is there a player that can allow me to specifically select which audio channel I want to use when I am playing the VCD? Also, if I were to rip this CD, which program should I use ( I just want 1 language, not both of them ).
Thanks in advance for your time.
There are a few posts like this, and sometimes its just a matter of deleting the left channel and adding the right to the left to get stereo.
You don’t "Rip" VCD's you either do a disk to disk copy, or copy the .dat file from your CD and edit/change and use that to make another VCD
TMPGEnc and Vdub will load the .dat file
Vdub .dat > AVI
Save out audio, use www.goldwave.com to edit WAV
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 18:06 -
How to extract audio from a VCD?
By c1steady in forum AudioReplies: 2Last Post: 14th Jan 2010, 21:16 -
CRT TV (SDTV) - when i play 16:9 movies and chose Pan n Scan it doesnt wor
By dzsoul in forum DVB / IPTVReplies: 17Last Post: 14th May 2009, 17:28 -
Extract audio only from VCD
By ambrosechapel in forum AudioReplies: 2Last Post: 19th Aug 2008, 22:24 -
extract vidio and audio from VCD
By Z.K. in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2007, 13:50
