I have made some MP3 cds using Easy CD Creator Platinum. They are at a CBR 192kbs. Although I only have 20 mp3s on the cd, when I put it into the dvd for playing the mp3 menu shows 80 mp3s. The dvd is splitting each track into 4 for some reason although it plays the song all the way through and I have noticed that the counter on the dvd reverts back to zero about 3 times when playing 1 song. The songs also sound choppy. Do I need to do anything in the settings of the player or does anyone know how I can stop this happening.
My Pc shows the correct amount of mp3s and they play fine.
Thank you.
Maria
Results 1 to 1 of 1
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 18:23 -
Panasonic DMP-BD45 & 65 & DivxHD?
By inoueto in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Aug 2010, 17:46 -
Creating a DVD using VOBS & MP3s
By ZenFrog76 in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2009, 03:00 -
Best Software to Edit VOR & IFO Files from Panasonic RAM Disk & Arc
By JDex in forum Newbie / General discussionsReplies: 16Last Post: 30th Sep 2009, 05:55 -
Help to review Panasonic AG-DVX100B & AG-HSC1U
By ChristianPaprika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 8th Aug 2007, 13:07
