I convert an Avi file with Tempenc to mpeg1. When i trie to burn it with Nero i got the next notice:
The file D:\Films\Titels\ The Time Macine\Cd1.mpg is not a valid file for creating a standard Video CD V2.0 (CD-I player) disc A compliant video file requires the following specifications: MPEG-1 which was encoded for Video-CD: audio: 44,1 Khz; sterio; 224 Kbit/s video 352x240/29,97 Hz or 352x240/23,976 Hz or 352x288/25 Hz.
The following problems were found:
-stream encoding which is invalid for a (super)Video-CD
How would you like continue?
-Turn odff standard compliance and continue
-Re-encode the video file
-Cancel.
What went wrong by the convertion, what is the best option and what say notice?
Krammie
Sounds like it's not VCD compliant. Check the following link:
http://www.vcdhelp.com/tmpgenc.htmIt's not what you know. It's what you can prove. -
Originally Posted by Krammie
then see if your standalone will play it.
or, if you know what settings you used in TMPG, check to make sure that your player will play an XVCD with those settings. did you change the sampling frequency to 44.1 k?
if you don't know the settings, you can download bitrate viewer, and look at your mpeg with that to see your settings, and then check if your player...what are you askin' me for...
I'm an idiot!
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero Burning Rom 8.3.6.0
By jebinio in forum ComputerReplies: 1Last Post: 14th Sep 2008, 10:29 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 22:04 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 08:35 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36
